TwinTurbo.NET: Nissan 300ZX forum - So is the problem actually with the head? I'm confused. (n/m)
Stadsport (PHX)
on August 06, 2011 at 2:30 PM
yep, you're correct
posted by aliaZ
on August 06, 2011 at 11:26 AM
soft valves
aliaZ
10:57:27 08/06/11
Re: soft valves
Tech@EPR
11:08:59 08/06/11
This is a known problem with the "30" valves - has been
Ash's Z
11:16:37 08/06/11
Re: This is a known problem with the "30" valves - has been
Tech@EPR
11:27:40 08/06/11
Re: Re: This is a known problem with the "30" valves - has been
aliaZ
11:29:54 08/06/11
Re: Re: Re: This is a known problem with the "30" valves - has been
Tech@EPR
11:37:02 08/06/11
I'm going to install a set of low mileage heads that I had
aliaZ
15:13:54 08/06/11
Re: I'm going to install a set of low mileage heads that I had
Tech@EPR
17:43:51 08/06/11
*cough cough* (n/m)
Ash's Z
12:00:41 08/06/11
the motor is completely stock
aliaZ
11:27:44 08/06/11
Ironically, I had the "solf valves" hardness tested a long
Ash's Z
11:15:10 08/06/11
yep, you're correct
aliaZ
11:26:23 08/06/11
So is the problem actually with the head? I'm confused. (n/m) -
Stadsport (PHX)
14:30:36 08/06/11
no it is a valve problem (n/m)
aliaZ
14:59:23 08/06/11
Typical "30" intake valve.
Russell@Z1
13:02:58 08/06/11
Not really a soft valve
toykoz32
13:47:16 08/06/11
correct
aliaZ
14:58:14 08/06/11
Good write-up
OverZealous (CT)
20:03:37 08/06/11
My 90 had them. I came across it a few years ago. (n/m)
ELDIABLO
10:05:18 08/07/11
